Back
Roaming with BT Mobile
What can we help with?
  • Using BT Mobile abroad
    Get advice on using your BT Mobile abroad, preparing to go, costs when travelling and help if you're having issues when abroad.
  • International network compatibility
    Check BT Mobile’s international network compatibility before you travel. Find out which countries support your device and how to stay connected abroad.
  • Roaming costs and charges
    Information about the costs and charges that you need to be aware of if you're going to use your BT mobile outside the UK.
  • Accidental roaming
    This article covers how your mobile device may accidentally connect to a network outside of your plan, in the UK or abroad, and what you can do about it.
  • Countries where BT Mobile doesn't work
    Find out where BT Mobile works abroad and which countries have limited service. Learn about places with no coverage and how to check international network compatibility.
Go back to: Mobile help
