Back
Increase my broadband allowance
If the usage allowance of your current broadband package isn't enough, you should change to an option with a higher allowance.
If the usage allowance on your current broadband package isn't enough, you should switch to a plan with a higher allowance. Options with unlimited usage allow you to upload and download as much as you want without worrying about being charged for additional usage.
Upgrade your broadband at www.bt.com/broadband/upgrade.
Why is my usage higher than I expected?
  • Additional devices - if you've got more than one computer at home, or devices such as games consoles or mobile phones that use Wi-Fi.
  • Viruses - without you knowing, viruses on your computer can access your internet connection in the background. So it's important that you've got an up-to-date virus checker installed.
  • Insecure wi-fi - make sure your wi-fi security is switched on to prevent other people from using your broadband. See Help for Hubs for help with Hub security.
  • Peer-to-peer (P2P) uploads: since the usage allowance includes both uploads and downloads, any P2P file requests will contribute to your total usage. If this becomes a problem, you can adjust the setting on your P2P software or remove it completely.
  • Background activity - certain software may access the internet directly from your computer to install updates.
Thanks for your feedback
Submit
