You can change your network name and password from either the app or a web browser:
From the My BT app:
- Select More.
- Select Your Wi-Fi network.
- Select Manage your Wi-Fi settings .
- Select Change your Wi-Fi name and password.
- Enter your new Wi-Fi network name and/or password
- Select Save
Using a web browser:
- Make sure you are connected to your Whole Home Wi-Fi network.
- Enter 192.168.1.254 in your internet browser address field.
- Enter your Admin password.
- Select Login.
(Admin password is printed on your wireless settings card located on the back of your discs) - Select Settings, then Wireless.
- Enter your new network name and password and click on Save.
