Save time on the phone if you're having BT Broadband problems, here are some tests you can run at home to try and resolve it.
Fix a problem with broadband and Wi-Fi
Help articles for fixing broadband problems
BT Broadband connection problems -
I want to improve my Wi-Fi Read how to connect 5GHz and dual band devices wirelessly, split your hub's wireless network name and connect to your hub (router).
Fix problems with Complete Wi-Fi Fix any Complete Wi-Fi problems you might have with your hub (router) or discs. See what the different lights mean and how best to connect a disc.
I have a problem with Halo What to do when you're having problems with your 4G back up connection (Halo) or problems with a 4G Mini Hub.
What do the lights on my BT Hub mean? Choose your hub (router) to see what the lights mean and find out what to do if you're having problems.
Can't connect devices Read how to connect your devices to wi-fi, disconnect from a BT hotspot, and how to connect using an ethernet cable.
What affects your home broadband speed? Use our broadband speed tester and troubleshooter to check your speed, find ways to improve it and get faults fixed.
Can't connect to a Wi-Fi network Discover why you can see a Wi-Fi network but can’t connect. Learn common causes and troubleshooting tips to get your devices online quickly.
