Help
Broadband help
Fix a BT Broadband Problem
What light are you seeing on your hub?
Your broadband is working
Back
BT Home Hub 3 - Blue Light
If you can't get online the issue might be with your device. Try switching it off and on again.
If you’re still having problems, get help from your supplier if you’re within your warranty period.
Need more help?
More options
Ask the BT Community
Contact us
