Back
BT Home SmartPhone - answering machine not recording messages
  1. Check the memory is not full. Your BT Home SmartPhone can digitally record up to 24 minutes of messages
  2. Check that the answering machine is turned on and set to Answer & record mode (if you have 'Answer Only' mode set the answering machine will not record messages)
    • Touch the Answer phone icon on the 'Home screen'
    • Press Menu
    • Touch Settings
    • Touch Answer mode
    • Touch Answer & record
  3. If you have BT Answer 1571 or a similar service, you may need to change the answer delay setting on your phone (the number of times the phone will ring before the answering machine takes the call) to ensure the answering machine takes the call before the answering service
  4. For BT1571, set the answer delay to not more than 5 rings
    • Press Menu
    • Touch Settings
    • Touch Answer delay
    • Select 5 rings
Thanks for your feedback
Submit
Need more help?
